Low Frequency Transformer
gone83
Hi, everybody...
I'm newbie here...if have problem in finding notes about low frequency transformer. Can anybody help me finding it?...Or can anybody explain this kind of transformer and what is the difference between the low frequency and high frequency? What is the major parameters in the transformer?
-someone help me!!-
gone83 said:
Hi, everybody...
-someone help me!!-
Well ...the usual step down transfomer from any adaptor (for example) is a low freq transformer. It's designed for 50-60 Hz but can be used for a bit higher freq (100Hz+). U can find in tubes or very old audio amplifiers tran designed for audio spectrum (20KHz +) and in intermediary freq small ones for 455KHz, 10.7 MHz etc.
The problem is that the low freq trans will chop higher freq wawes....su just don't use a adapter's trans for higher freq. Use below 100Hz to be sure.
gone83 said:
Hi, everybody...
-someone help me!!-
https://en.wikipedia.org/wiki/Transformer#Classifications
Read this and ...just use google for more.
If you need to run a transformer from a lower frequency than what it was designed for then you need it to be rated for double the voltage.
thanks you guys..actually i'm working on a battery charger...it using 120V and 60 Hz.
If there's any problem..I'll let guys know
TQ
