Logic Level MOSFET
olof102
I'm looking for a N-ch and a P-ch MOSFET that can handle 24V 6A and will switch on with the current from a PC's parallel port and it's voltage 3,3V.
Anyone?
Thanks in advance!
PS, I need it to a H-bridge that will run a 100W 24V DC motor.
Logic level Fets, like the IRL series from International Rectifier still require 4.5V on their gate. 3.3V is too low, and a much lower impedance source. You can easily fix this by adding some NPN small-signal transistors between the port and the gate. Write back if you need a diagram.
Thanks MiikeMI! Please do send me the diagram!! I have a lots of small signal transistors so that shouldn't be a problem, just let me know how to wire it up! =)
One other caution: When a PC boots up, the parallel port pins do a complicated dance (I'm guessing that is used by the mother board manufacturer for testing). If your 24V power supply is turned on during PC boot-up, the port pins may hit the exact pattern that happens to turn on both the top and bottom transistor of your H-bridge, which will blow up something.
Last time I did this, I had to use a decode of the port pins and some of the bits from one of the status registers to enable the external drivers. I experimentally had to find a unique bit pattern which never happens during the boot-up sequence.
One other question: Will you be controlling the gates of the high-side (P-Channel FETs) from the PP? (IOW: are you using 2bits from the PP or 4?)
Oh, then I'll keep in mind to dissconnect the cable between computer and H-bridge during startup.
Sorry for noob questions, How do I know if I'm using 2 bits or 4 bits?
I have written a proram in C++.
#include <stdio.h>
#include <dos.h>
void main(void)
{outportb(0x378,0x00);
00 = 0V on datapins
01 = 3,3V on Datapin1
02 = 3,3V on Datapin 2
And so on I guess...?
Is this what you mean?
Will I be able to control the direction of the motor with this code?
Thanks!
#include <stdio.h>
#include <dos.h>
void main(void)
00 = 0V on datapins
Thanks!
Read this thread. This is an example of an H-Bridge that can be controlled with only two bits.
