LM35 Code
AtomSoft
Hey guys i just got my LM35 in the mail and am glad to say its so much easier to use than the LM75 heh.. Here is a picture from ISIS.. It works well live also:
Below the picture is full source code for LCD, LM35 (ADC MANUALLY)
lm35-jpg.34560
OR
LM35_ADC.zip
Tested again and might cause extra character to appear on LCD so here is new main.c file:
;    Filename:                     				                              *
;    Date:        *
;    File Version: 001                                                        *
;    Author:   Jason Lopez                                                    *
;    Company:  AtomSoft                                                       *
#include <p18F4620.h>
#include <delays.h>
#include <string.h>
#include "lcd.h"
#pragma config WDT = OFF, LVP = OFF, OSC = HS, XINST = OFF
Prototypes
void main(void);
unsigned char DECtoBCD(unsigned char DEC);
unsigned char DECtoASCII(unsigned char DEC,char part);
Variables and Defines
    #define ADCPin TRISAbits.TRISA0 // RA0/AN0 TRIS (DATA DIRECTION REGISTER)
    unsigned int result; //Result Variable
    unsigned int DegC;   //Result in Celsius
    unsigned int DegF;   //Result in Fahrenheit
    unsigned char lcdtmp[10];
Main
void main(void){
    ADCPin = 1;                     //AN0 = Input
    ADCON0 = 0x00;                  //BIT 7:6 Always 00, BIT 5:2 is 0000 for Channel 0 (AN0),
                                    //BIT 1:0 is 00 (A/D Idle and Module is off) until we are done setting up
    ADCON1 = 0x0E;                  //BIT 7:6 Always 00, BIT 5 is 0 for VSS, BIT 4 is 0 for VDD
                                    //BIT 3:0 is 1110 for all digital expect AN0. We need it analog so we can convert it.
    ADCON2 = 0b10001101;            //BIT 7 is 0 for Left Justified, BIT 6 Always 0, BIT 5:3 001 for 2 TAD (A/D Acquisition Time)
                                    //BIT 2:0 is 100 for FOSC/4 for A/D Conversion Clock
    ADCON0bits.ADON = 1;            //Turn on the A/D module
    LCD_Init();
    DelayMS(100);
    LCD_LINE(1);
    LCD_STR((unsigned rom char*)"  AtomSoftTech  ");
    LCD_LINE(2);
    LCD_STR((unsigned rom char*)"Temp: ");
	while(1){
        ADCON0bits.GO = 1;          //Start the conversion
        while(ADCON0bits.DONE);     //Wait until it’s done
        result = ADRESH;            //Load ADRESH into result
        result <<= 8;               //Shift over Result 8 bits to the left
        result |= ADRESL;           //OR in our LOW byte to finish off out INT
        DegC = (result*5)/10;
        DegC--;
        DegF = DegC * 9;
        DegF/=5;
        DegF+=32;
        lcdtmp[0] = DECtoASCII(DegC,'h');
        lcdtmp[1] = DECtoASCII(DegC,'l');
        lcdtmp[2] = 'C';
        lcdtmp[3] = '-';
        lcdtmp[4] = DECtoASCII(DegF,'h');
        lcdtmp[5] = DECtoASCII(DegF,'l');
        lcdtmp[6] = 'F';
        lcdtmp[7] = lcdtmp[8]  = lcdtmp[9] = ' ';
        LCD_LINE(2);
        LCD_STR2(lcdtmp);
        DelayMS(1000);
unsigned char DECtoASCII(unsigned char DEC,char part){
unsigned char temp;
unsigned char myData;
    temp = DECtoBCD(DEC);
    if(part == 'l')
        myData = temp & 0x0F;
    if(part == 'h')
        myData = (temp >> 4) & 0x0F;
    myData += 0x30;
    return myData;
unsigned char DECtoBCD(unsigned char DEC){
unsigned char temph;
unsigned char templ;
    templ = DEC % 10;
    temph = DEC / 10;
    myData = (temph << 4) | templ;
    return myData; //Return myData
Heh more update:
This code averages 10 readings all 10mS apart. So it takes 100ms to get 1 stable reading but heh its worth it...
;    Filename:                     				                              *
;    Date:        *
#include <delays.h>
#include <string.h>
#include "lcd.h"
Prototypes
void main(void);
    unsigned char avg[10];
Main
void main(void){
    unsigned char tmp;
    LCD_Init();
    DelayMS(100);
    LCD_LINE(1);
    LCD_LINE(2);
	while(1){
      for(tmp=0;tmp<10;tmp++){
        avg[tmp] = result;
        DelayMS(10);
        result = 0;
            result += avg[tmp];
        result /= 10;
        DegC--;
        DegF = DegC * 9;
        DegF/=5;
        DegF+=32;
        lcdtmp[2] = 'C';
        lcdtmp[3] = '-';
        lcdtmp[6] = 'F';
        LCD_LINE(2);
        LCD_STR2(lcdtmp);
        DelayMS(1000);
        DelayMS(1000);
unsigned char temp;
    if(part == 'l')
    if(part == 'h')
    myData += 0x30;
    return myData;
    templ = DEC % 10;
    temph = DEC / 10;
Here is the new code... Thanks for the tip :)
;    Filename:                     				                              *
;    Date:        *
#include <delays.h>
#include <string.h>
#include "lcd.h"
Prototypes
void main(void);
Main
void main(void){
    unsigned char tmp;
    LCD_Init();
    DelayMS(100);
    LCD_LINE(1);
    LCD_LINE(2);
	while(1){
        avg[tmp] = result;
        DelayMS(10);
        result = 0;
            result += avg[tmp];
        result /= 10;
        DegC--;
        DegF = DegC * 9;
        DegF/=5;
        DegF+=32;
        lcdtmp[0] = DECtoASCII(DegF,'h');
        lcdtmp[1] = DECtoASCII(DegF,'l');
        lcdtmp[2] = 0xDF;
        lcdtmp[3] = 'F';
        lcdtmp[4] = ' ';
        lcdtmp[5] = DECtoASCII(DegC,'h');
        lcdtmp[6] = DECtoASCII(DegC,'l');
        lcdtmp[7] = 0xDF;
        lcdtmp[8] = 'C';
        lcdtmp[9] = ' ';
        LCD_LINE(2);
        LCD_STR2(lcdtmp);
        DelayMS(1000);
        DelayMS(1000);
unsigned char temp;
    if(part == 'l')
    if(part == 'h')
    myData += 0x30;
    return myData;
    templ = DEC % 10;
    temph = DEC / 10;
Heh more update:
You wouldn't be able to read it that fast anyway :) But if it bothers you, you could use that digital_filter code I put in your other thread.
Edit: I just went and looked at your code a bit more closely. You have delays of several seconds in the code, I don't think you're worried about the 100mS you spend reading the ADC so nevermind.
nice one jason, i been studying your code while i learn, much of it goes over my head but i am starting to understand parts of it! is amazing how much and how quick i can learn on this site. i might to start taking back all the bad things ive said about the net :D
