Hello,
I'm using an LM1086ILD-3.3/NOPB to power a pic. The input is 5V, I had to solder wires to the pads due to a bad foot print layout, but I noticed that if I only use the bottom center pad as the output the voltage will not be 3.3V with load or no load, it was more like anywhere from .8V to 1.1V. I then soldered the rest of the output pads and tied them together to the bottom center output one with 30AWG wire. This fixed the issue for me and everything is working fine with a load or no load. I'm curious to find out why it worked this way. Any insight will be appreciated.
