For a bit of background see this thread https://www.electro-tech-online.com/threads/thoughts-on-new-project-idea.147085/
In a nutshell I wasnt going to do my Art exam or project, then had a brainwave on how to make it less boring and throw a load of electronics into it! It also fits my remit for the next relaxation project (yes I solder just for fun).
So I decided to go with Lissajous laser light and sound show, while it has been done to death I wanted to add a couple of twists. So first off for those landing from planet google, this is not a intentional tutorial but more of a project progress thread.
First off the easy bit...........
SIMPLE PATTERNS
The thinking so far (and it could change) is too have 3 lasers (different colours), these will point into mirrors probably made from old CD's. that I mount on old PC fans or similar. The fans are going to be mounted on servos for both the X and Y axis, this is simply to alter the angle of the mirrors and dosnt have to fast. I could use old CD case stepper motors with the screw thread for this but not sure yet.
The sound will be stereo and fed into band pass filters, the filters will be user adjustable via pots. The speed of the fans and to some extent the position of the fans will be controlled via the signal from the filters (using ADC from micro). The idea for this bit is not to be completely in sync but to be tethered a bit to the music but allow the user to adjust some the filters and therefore pattern. So we should end up with something a little bit like this, but controlled mainly by music.
The next bit is harder.
Taking it a step further the mirrors will be stationary and the pattern controlled by vibrating the mirrors, again the other thread has some chat on how this might be done but at the moment I am flexible. What I am aiming for is patterns done to music like the second video (below), but instead of an OScope I will use the laser. It Sounds complicated but I dont think it will be, I have messed with Matlab and the patterns being mathematical or not too bad to do. The next video shows the effect I am after.
This one shows some other things that can be done, having a play for a short while with software it dosnt seem to hard to do. I am not worrying about how to move the laser's yet as this can be done a million ways.
I wasnt going to bother with the Art exam but having read the brief for it I realized I could make it cool, and have it fit what I wanted to do for the next project (just for fun). I have two weeks to play and decide if I am going to do this exam (its a resit, as i didnt show for the first exam), if I go ahead then I will have another 5-6 weeks (ish) to do the project. If I get as far as the patterns on the OSCOPE I will go with that, but the aim is to do this with lasers..
QUESTIONS I AM UNSURE OF.
Some of these will seem silly, but some of them have never cropped up for me before. I want to try some the patterns on the scope, I have 3 function generators and will be using the scope in X,Y mode. All my FG's are either single channel or a mix of high frequency/low frequency outputs. I dont have one that will out put two different signals at the same time (one driving X One driving Y).
1) Can I safely tie the grounds from my FG's together and feed one signal into X channel and the other into Y Channel?
3) If I do tie my grounds do I then also tie it to the scope ground? I am concerned with ground loops and have never tried two FG's at the same time
Or do I simple tie FG1 to X channel including the ground from FG1 to Ground on scope X channel? And do the same with FG2 to the Y channel?
Or Leave all the grounds untied?
At the moment I am not worrying about the other aspects, I just need a test set up first to try the patterns out as this will dictate what path I go down.
I will post each stage of the experiment and build in this thread
SIMPLE PATTERNS
