liquid conductivity meter
Please post more information, two carbon rods from old batteries will do the job.
Well you can't do it with direct current; you will get a reading for less than a second, then nothing. The reason is that the conductivity is a result of the ions present in solution, and passing DC will alter this.
You need some kind of oscillator (Wein Bridge, or similar) to create a sine wave. Between 1 and 10 kHz seems to work well. Then using this current, and your probes (an audio cord with a gold plated phone plug works well,) measure the resistance of the water.
Well, it isn't really like a pH meter. The pH sensor acts like a very small battery; it puts out a very high impedance voltage, either + or -. at pH 7.0, the probe will put out 0.0v. With that one you have to offset, and scale the output.
Which probe were you thinking of? Post a link, so we can look at it.
Like Hero said, more info.
BeeBop said:
Well, it isn't really like a pH meter. The pH sensor acts like a very small battery; it puts out a very low impedance voltage, either + or -. at pH 7.0, the probe will put out 0.0v. With that one you have to offset, and scale the output.
pH sensors have very high impedance.
They don't measure conductivity.
BeeBop said:
Whoops, yes that's what I meant. Edited for correctness.
I HOPE I didn't imply this:
but now that I read what I wrote, it kind of does sound that way.
I didn't mean to imply that you meant that, but I was aware that it might have sounded like you did. Sorry. :eek:
