moody07747
then ill use your wiring sheet
moody07747 said:ok im going to order these leds today
what voltage will i need for this circuit?
i want to wire it so it will be like the pic below
i wont hard wire this all, ill have it so thres a plug on each drum so i can take them off the stand and put them away if needed
the pic: yes those are diode symbals but just say they are LEDs for now
each blue point is a solder
theres a switch at the bottom and a power supply
i dont know what voltage lights these LEDs up because it does not say on digikey
so i need to know what voltage ill need to power this up
i also want to run it on a transformer so i can run off 120V
moody07747 said:one question audioguru
How did you come up with the 82ohm resistor?
I could never figure that one out but never really searched on it much...is there some calculation that you do to find that?
audioguru said:Too much glue takes a long time to harden. I think they are designed for very thin layers of glue.
