Led strip turn signal
alex1991
Hi all, so before I do some damage to my car I need your advice
I want to install this cool led turn signal strips
https://www.amazon.com/CARLITS-Flexi...s%2C251&sr=8-5
And since there is already a nice gap between hood and light (front and back) and they fit perfectly, but:
When the car is off everything is working perfectly but as soon I turn the engine on the voltage drops down (around 10v) and the strip is not working.
Do you have any ideas about how could I get stable 12v from turn signal. I am thinking to use relay but I am not sure...
did you notice the first thing mentioned in the q&a at bottom of page?
what is the wattage on the original flasher bulb?
my drl flickers when connected - is the module defective ?
Answer:
It's likely your cars PCM doesnt like LED's and you either need a load resistor or you need to wire the running LED into something else. Say the radio fuse wiring. Or you can buy a 10 amp Fuse Tap and wire it that way.
