LED resistor
DSGarcia
Not quite sure, but I have an illuminated switch with an LED. Brightness specs are given "@20mA" and the forward voltage is given as 2.3V. I have a 24VDC supply.
What is a good value for the resistor? 24V@20mA gives me 120 ohms which seems low to me.
Thanks,
Dale
Diver300
Most Helpful Member
You have a decimal point in the wrong place. It should be 1200 :eek:hm:.
In fact, if you allow for the forward voltage, only 21.7 volts is left across the resistor. So that should be 1085 :eek:hm: to get 20mA
However, you won't loose much brightness at lower currents so you could use 1.5 k:eek:hm: to 2.2 k:eek:hm:. That would also be less likely to damage things if the voltage is a bit above 24V.
shaneshane1
If your not to sure how that works out its done like this.
24V(power supply) - 2.3V(the LED's voltage drop) / 0.020(20mA) = 1085ohms
so
24 - 2.3 / 0.020 = 1085
anywhere close to that will be fine
hope this helped you as well
Hero999
Banned
Also note the power disipation of the resistor will be 21.7^2/1200 = 392.4mW so a 1/4W resistor won't do, a 1/2W resistor will work fine.
slosjo
It may or may not be important for your application, but it dosen't hurt to also add a small ceramic cap (0.01uF or so) across the anode and cathode of the diode. It will help absorb voltage spikes that could be present if the LED was part of a larger system that could be subject to EMI.
