I have built a LED Emergency Flasher unit for the top of my vehicle when doing snow removal. I am using yellow LED marker lights. It works pretty well, but it would be much better if I could step up the 13.8 VDC to an estimated 15 to 18 volts to get a brighter flash. (I could determine the desired voltage by using a variable DC voltage supply first.) I'm hoping the short duration flashes will not damage the LEDs. (It is only consuming less than an amp.)
The only way I can think of to do this, is to pulse DC through a step-up transformer, and rectify the output to feed to the LEDs. That may also be a good way to flash them. That will take some trial and error.
Is there a chip package that I can use for most of it, or perhaps a simple trick? (Adding a battery would be undesirable.) Perhaps someone can suggest a circuit to meet my needs.
Thanx, N0CE
Thanx, N0CE
