LED circuit
sicktight31106
I am in the early stages of planning to upgrade my cars brake lights to LED and I was wondering what LED would fit my application best.
I am planning on adding 20 LEDs (10 on drivers side, 10 on passenger side) to my existing brake light circuit. I don't know much about LEDs so I dont know how to go about starting this project.
here are two LEDs that I found that I was wondering would work, the first is a 8mm 8000mcd red LED;
https://www.ledshoppe.com/Product/led/LE1012.htm
and the other is a 10mm 10000mcd red LED;
https://www.ledshoppe.com/Product/led/LE2002.htm
thanks for your inputs!
The description doesn't state luminous intensity (Lumen). The values given in mcd refer to view angle and the power output for the LEDs.
An equation mcd -> Lumen cannot exist for that reason.
Brake lights are normally rated 20W.
I guess 12 LEDs of either kind will be sufficient if you use the reflectors inside the brake light enclosure to enlarge the narrow view angle of just ±10degrees.
Boncuk
