LDR to pass audio.
makaze
Hi.
I would like to build a circuit that uses LDR's or other devices to pass or block an audio signal.
Simply I would like to pan an audio signal left to right in response to one or more LED's blinking.
Thanks for any input.
Tom.
About 40 years ago I used Light Dependent Resistors to adjust gain in audio. The LDR responded a little slower than I liked but it did work.
I put a LDR and light bulb (LED in your case) in a heat shrink tube to keep room light out.
Hi.
Tom.
How many dB of range do you need? What are you controlling the action from?
There are a few ways to control audio, with different trade-offs of functionality. Which is best will depend on what the rest of your needs are.
As already mentioned, LDR's are fairly slow - and in Ron's case bulbs greatly more so - which was an advantage, a bulb/LDR combination gave pretty good attack/decay for AGC etc. :D
I also built an LDR/lamp attenuator using the concepts described above. Boy, that was years ago!
The most difficult part, if I remember correctly, was to match the input voltage vs attenuation in the two channels across the control voltage range. LDRs have a wide, wide tolerance.
Also, if I remember properly, LDRs wavelength response is fairly similar to the human eye, meaning that for best performance use green LEDs.
