I have a tm162acw lcd 2x16 screen
i have used nigel's tutorial 9.2 to connect the screen and hex keypad to test with.
When i start apply voltage the screen comes up blank.
I tried to adjust the contrast you can see something is there but can't read it.
After awhile the writing appears.
When you enter the code the numbers show on the second row then the screen goes
blank. I know it is not the code. I have used a 16f628a and have changed the .inc file.
I suspect that the display is faulty.
I set the lcd voltage to 0,3v as per the data sheet
any advice.
any advice.
