lcd library
bernage
i am having trouble adding a lcd library to mplabx. does anyone know the solution? i am getting error like this:
CLEAN SUCCESSFUL (total time: 3ms)
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[1]: Entering directory 'C:/Users/berna.eker/MPLABXProjects/ghg.X'
make -f nbproject/Makefile-default.mk dist/default/production/ghg.X.production.hex
make[2]: Entering directory 'C:/Users/berna.eker/MPLABXProjects/ghg.X'
"C:\Program Files\Microchip\xc8\v2.36\bin\xc8-cc.exe" -mcpu=16F876 -c -mdfp="C:/Program Files/Microchip/MPLABX/v6.00/packs/Microchip/PIC16Fxxx_DFP/1.3.42/xc8" -fno-short-double -fno-short-float -O0 -fasmfile -maddrqual=ignore -xassembler-with-cpp -mwarn=-3 -Wa,-a -DXPRJ_default=default -msummary=-psect,-class,+mem,-hex,-file -ginhx32 -Wl,--data-init -mno-keep-startup -mno-osccal -mno-resetbits -mno-save-resetbits -mno-download -mno-stackcall -mdefault-config-bits -std=c99 -gdwarf-3 -mstack=compiled:auto:auto -o build/default/production/lcd.p1 lcd.c
"C:\Program Files\Microchip\xc8\v2.36\bin\xc8-cc.exe" -mcpu=16F876 -c -mdfp="C:/Program Files/Microchip/MPLABX/v6.00/packs/Microchip/PIC16Fxxx_DFP/1.3.42/xc8" -fno-short-double -fno-short-float -O0 -fasmfile -maddrqual=ignore -xassembler-with-cpp -mwarn=-3 -Wa,-a -DXPRJ_default=default -msummary=-psect,-class,+mem,-hex,-file -ginhx32 -Wl,--data-init -mno-keep-startup -mno-osccal -mno-resetbits -mno-save-resetbits -mno-download -mno-stackcall -mdefault-config-bits -std=c99 -gdwarf-3 -mstack=compiled:auto:auto -o build/default/production/newmain.p1 newmain.c
::: advisory: (2049) C99 compliant libraries are currently not available for baseline or mid-range devices, or for enhanced mid-range devices using a reentrant stack; using C90 libraries
In file included from lcd.c:9:
./lcd.h:21:2: error: unterminated conditional directive
#ifndef LCD_H
In file included from lcd.c:10:
In file included from ./newmain.c:21:
#ifndef LCD_H
In file included from newmain.c:21:
#ifndef LCD_H
1 error generated.
2 errors generated.
make[2]: *** [build/default/production/newmain.p1] Error 1
make[2]: *** Waiting for unfinished jobs....
make[2]: *** [build/default/production/lcd.p1] Error 1
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
(908) exit status = 1
nbproject/Makefile-default.mk:123: recipe for target 'build/default/production/newmain.p1' failed
nbproject/Makefile-default.mk:115: recipe for target 'build/default/production/lcd.p1' failed
make[2]: Leaving directory 'C:/Users/berna.eker/MPLABXProjects/ghg.X'
nbproject/Makefile-default.mk:91: recipe for target '.build-conf' failed
make[1]: Leaving directory 'C:/Users/berna.eker/MPLABXProjects/ghg.X'
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
BUİLD FAILED (exit value 2, total time: 665ms)
All three errors are from the same source..
#ifndef LCD_H
That means the #endif may be missing.. Normally happens when you cut and paste.
Check the file LCD.H and see if this line is missing.
You should have three lines
C:
#ifndef LCD_H
#define LCD_H
#endif
Ian beat me to it..
Note that the #endif should be at the end of the file, so all the content is skipped one it's been seen the first time.
#ifndef LCD_H
C:
#ifndef LCD_H
#define LCD_H
#endif
Thanks, but the problem is not caused by this, I wrote them in lcd.h.
Thats my lcd.h ;
#ifndef LCD_LIB_H
#define LCD_LIB_H
#include <xc.h>
#pragma config FOSC = XT
#pragma config WDTE = OFF
#pragma config PWRTE = OFF
#pragma config CP = OFF
#pragma config BOREN = ON
#pragma config LVP = ON
#pragma config CPD = OFF
#pragma config WRT = ON
#define _XTAL_FREQ 8000000
#define rs RB0
#define rw RB1
#define e RB2
#define port_lcd PORTC
#define Sil 1
#define BasaDon 2
#define SolaYaz 4
#define SagaYaz 6
#define ImlecGizle 12
#define ImlecAltta 14
#define ImlecYanSon 15
#define ImlecGeri 16
#define KaydirSaga 24
#define KaydirSola 28
#define EkraniKapat 8
#define BirinciSatir 128
#define IkinciSatir 192
#define KarakUretAdres 64
#define CiftSatir 40
#define TekSatir 32
extern void bekle (void);
extern void veri_yolla(unsigned char);
extern void lcd_sil(void);
extern void lcd_yaz(const char *s);
extern void lcd_gotoxy(unsigned char x, unsigned char y);
extern void lcd_hazirla(void);
extern void lcd_komut(unsigned char c);
#endif
This is LCD.C project
#include "LCD_lib.h"
void bekle(void)
__delay_us(250);
rw = 0;
rs = 0;
e=1;
port_lcd = ( c & 0xF0 );
e=0;
bekle();
e=1;
port_lcd = ( (c & 0x0F)<<4 );
e=0;
bekle();
void veri_yolla(unsigned char c)
rw=0;
rs=1;
e=1;
e=0;
bekle();
e=1;
e=0;
bekle();
void lcd_sil(void)
lcd_komut(Sil);
__delay_ms(2);
void lcd_yaz(const char * s)
bekle();
while(*s)
veri_yolla(*s++);
void lcd_gotoxy(unsigned char x,unsigned char y)
if(x==1)
lcd_komut(0x80+((y-1)%16));
else
lcd_komut(0xC0+((y-1)%16));
void lcd_hazirla()
rs = 0;
e = 0;
rw = 0;
__delay_ms(15);
e=1;
lcd_komut(0x02);
__delay_ms(2);
lcd_komut(CiftSatir);
lcd_komut(SagaYaz);
lcd_komut(ImlecGizle);
lcd_sil();
lcd_komut(BirinciSatir);
And my MAİN C file
void main(void)
TRISB = 0;
TRISC = 0;
lcd_hazirla();
lcd_yaz("MPLABX");
lcd_gotoxy(2,1);
lcd_yaz("XC8");
while(1){}
Can you tell me where is the problem please?
So, the original error has gone now you've corrected lcd.h?
If you can compile the code into a hex file then there are no errors. I don't know how to load a hex file using pk3.
When I export this code as a hex file, I cannot ‘write’ via pickit3. pickit recognizes the microcontroller but cannot send data to the mc. I think there is an error in the code.
Or you have selected the wrong part.. What micro are you using... Pickit3 may need an adapter to program...
