LCD display code problem
I am stuck on one simple thing.
I have 20x04 LCD display with IC2 board (the last one here): **broken link removed**
Here is what i want. If digital pin 6 is 5V, then write 5 on LCD, or if pin 6 is 0V, then write 0
void loop()
lcd.home ();
lcd.clear();
int x
if (LED2==HIGH) x=5;
else x=0;
lcd.setCursor ( 0, 2 );
lcd.print (x);
delay (200);
LCD always shows 0, even when it is not. And even when i reset atmega 328p
Please help me if you know what is wrong in my code
Here is the whole code:
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
int REED = 4;
int LED = 8;
int LED2 = 6;
int x = 9;
LiquidCrystal_I2C lcd(0x20, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address
void setup()
Serial.begin(9600); // Used to type in characters
lcd.begin(20,4); // initialize the lcd for 20 chars 4 lines and turn on backlight
lcd.backlight(); // finish with backlight on
lcd.setCursor(3,0); //Start at character 4 on line 0
lcd.print("Hello");
void loop()
lcd.home ();
lcd.clear();
int x;
else x=0;
lcd.print (x);
delay (200);
What sets D6 high or low? ME :) I manually put DIGITAL pin 6 (PIN 12 fisically) to GND or to +5V..
It is normally 0V, and it display it says 0, but when i put 5V to it, it still says 0..
int LED2 = 6;
LED2 will ALWAYS be high... You assigned the variable a 6...
You need to assign a pin to an output..
pinMode(LED2, OUTPUT);
Then control it... Set it high..
digitalWrite(LED2, HIGH);
Or low..
digitalWrite(lLED2, LOW);
I don't know whether you can read a pin whilst in output mode..
ledState = digitalRead(LED2);
If not you'll need an output buffer so you can read the buffer instead of the pin...
Ian's right on the money. Testing the value 6 will always equate to high.
To get to where you want to be with reading a pin you're externally toggling,
if(digitalRead(LED2)==HIGH) x=5; else x=0;
will do the trick. Or, since HIGH and true are the same internally to an Arduino, you could simplify this to
if(digitalRead(LED2)) x= 5; else x = 0;
You can read a pin in output mode so that last part is fine. I'll often use
digitalWrite(!digitalRead(LEDPIN));
to toggle a LED from whatever state is it is to the alternative on an output pin and that's all good.
Cheers !
Geoff
You are awesome ! Thank you :)
Here is what i did, and now it works great. Finally!
#include <Wire.h>
int REED = 4;
int LED = 8;
int LED2 = 6;
int x = 9;
void setup()
pinMode(LED2, INPUT);
lcd.print("Hello");
delay(500);
void loop()
lcd.home ();
lcd.clear();
int ledState;
int x;
if (ledState==HIGH) x=5;
else x=0;
lcd.print (x);
delay (200);
That pin 6 is input pin, it will be connected to the switch, so i dont need digitalWrite on it but i get the point :)
