OK... I've been looking at various circuits using 555 to build the timed portion of the circuit but I'm not sure I need this level of complexity. Here's what I'm trying to achieve.
I'm building a battery powered filtration and evac system for another unit. I would like to have the circuit operational between 4.5vdc and 6vdc. This circuit will be in a non powered state until the activation button is pressed. Once active, the circuit should remain powered for about 3-5 min at which time it will shut off. A second switch can activate and hold the circuit from counting down via a pressure activated switch. It will close at aprox 30 lbs of pressure. Once released, the circuit would then remain powered for about 3-5 min. A third n.o. switch can be pressed to shut the circuit down and remove power to conserve battery. Correct me if I'm wrong, but I was thinking I could do this completely analog using a capacitor with a controlled charge rate to act as my timer.
Any thoughts?
Any thoughts?
