I need to set up a circuit that uses tactile switches as inputs and led's as outputs and operates under the following conditions:
- two Led's each have a respective tactile switch
- pushing Button "a" turns on it's respective LED and stays illuminated until "a" is pressed again and then the light goes out
- if button "b" is pressed while the "a" LED is on, the "b" LED turns on also (BOTH LED's should be on at this point) until either "a" or "b" is pressed.
- pushing button "b" turns on BOTH LED's until either button is pressed and then they BOTH go out
I guess im mroe or less looking for the appropriate chip to use for this. I wish there was a way i could find some sort of directory to see what chip does what but I have a feeling that most of this application know-how just comes from experience.
-tim
-tim
