After desoldering a few trim pots off junk boards, and realizing that I could probably order some quicker then finding something close to what I was looking for, I though there has to be a quicker way.
Mostly, I've only used the wick/braid or sucker method, occasionally the propane torch/5 gallon bucket method (outdoor activity). Just wondered if anybody has come up with a better method of removing the parts from junk PCBs in mass.
Was kind of thinking about using a clothes iron and a shop-vac. Don't know if it gets hot enough, pretty sure its over 300 degrees (laser toner transfer). Figure if I could drill some holes through the bottom for airflow, cut a big hole in the side for the shop-vac hose. When the solder liquidfies, it gets pulled off the board, parts should basically fall off the board.
Yeah, I get some wierd ideas sometimes when doing slow, boring tasks. Sometimes they really aren't this bad.
Recycling parts can't be completely taboo. I know some parts don't tolerate heat, and mostly will be destroyed or altered. But there many good parts that can be reclaimed and used. Like these trim pots, usually 2-3 for a dollar (US$), but usually the ones you want are a dollar or so each...
