I've been helping a friend to get a laptop PSU to work with his inverter. The inverter is "modified sine wave", so there are just three voltages, peak voltage forward, peak voltage reverse, and zero volts. The inverter seems to adjust the duty cycle so that the RMS voltage is 240 V. The peak voltage is very close to the peak voltage for a 240 V sine wave, but it does depend on the input voltage.
The laptop PSU is rated 110 - 240 V and it won't turn on when connected to this inverter.
It is fine on a very similar inverter, also "modified sine wave" and with a duty cycle that adjusts to keep the RMS voltage correct. This one has a slightly lower peak voltage, but the duty cycle is larger so the RMS voltage is the same.
I suspect that the laptop PSU doesn't work on the first inverter because the lower duty cycle means that the output is off for longer each cycle, and this longer off period makes the laptop PSU think the supply is intermittent.
Any other ideas?
For now I have connected the laptop PSU to the dc link voltage at 360 v dc, and it works fine. That is no surprise because all laptop PSUs that I have seen have a bridge rectifier on the input.
Any other ideas?
