blueroomelectronics
the small inductors will make it work harder to maintain VPP. The lowest I've used is 470uH and that works fine.
680uH coils are extensively used on the B&W Portable TV at the Video amplifier front end transistor collector. also on ET&T TVs picture tube grid transistor collector. and on color picture tubes Neck board, you find three of them.Mvs,
I'm in trouble. The maximum inductor value available here is 100 uH. That's simply not enough.
MVS told me I can use a transistor radio IFT in place of the inductor.
In those IFT's, there are two pins in one side, and other side has three pins.
So, where to connect;in the two pinned side or the three pinned side??
I'll remove the metal exterior, the tuning mechanism.
What things to be checked for Vpp error? I think :
the PNP transistor, the inductor, the IN4148 diode....any more??
and I use BC548B transistor in all NPN transistor places, which were 2N3904.
I use BC558 transistor in all PNP transitors places,which were 2N3906.
Both have reverse layout. ie C-B-E. the 2N390x have E-B-C layout.
Any problem...any suggestions???...Hope Mr. MVS will solve the IFT problem...
Mvs,
I'm in trouble. The maximum inductor value available here is 100 uH. That's simply not enough.............
