I mounted both programmers (**broken link removed** and Olimex PIC-PG2) on a different breadboards to program the PIC16F84A and found the same problem on both, the program voltage rises to 10.5V lower than the programming voltage range (12V to 14V) I’m using IC-Prog on WinXP with installed drivers to test the hardware and components like 2n3904, 1n4004, 6.2V 1/4W zener, 5.1V 1/4W zener, standard electrolytic capacitors and 1/4W Resistors. Tried the programmers with different computers and found the same result. Connected a MAX232 appropriately with all the external caps and external power (see figure) so I could take the power from the MAX232 instead of the computer serial port and it when I test it with ic-prog the programming voltage was 12.7V and all the other voltages were fine. Tried to program but verified fails and the simple program to turn on half of portB pins and turn off the other half doesn’t run.
How can I make the programmer rise MCLR to the programming voltage?
