Hi there fellows,
nice way to start a post in this community after a while i've been reading you.
Today i put my hands on a brand new USED HT kit from jbl.
I got it by a guy not near my door, so i make a shipment.
When i got it from the courrier, i find out, two satellite's cone with the frame slightly broken (it is in palstic!!!).
This is a mechanical issue, and i can explain that, a bad box has been made for that shipment.
What what sounds strange, is the subwoofer, that came with few scuff, simply did not work.
i take the amp apart, and i find that some tracks on the pcb was overheated.
That was related to a unknown C20 capacitor blown up.
I then fixed the tracks with some wire as you can see.
Then i bought a capacitor with the same size of on near him , the C19 (on the right in the picture) which is written 221 on it.
The resistor that you see blown up, was still not blowed.
I measured it, and it was 0.56 on the 2k scale on my tester.
I measured it while it was on board (i did not take it apart)
I wasn't able to understand the color, they really seems green-blue-black, but i cant really say what is the last color.
Back to the shop, i installed the new capacitor.
Closed up everything, and it was running fine.
Listen to the sub for a while , then it stop playing music, and it began with a continuous buzz, even at low to mute volume. A bad smell came out from the sub.
Itake it apart and realized that the resistor i was telling before, was now blewn up.
The capacitor was still there in good shape.
now, i need some help.
I am not able to find the service manual for this sub.
I find the link on this site of this, wich has pretty the same specs, but it is different (still 100w HT sub dunno if 4 or 8 ohm mine is 4)
then i find the manual to be paid here
JBL - SCS 175 Sub Service Manual on Windows Drivers Downloads
but it cost around 10 usd.
Do you think i am gonna find the right manual there?
Or do you amp gurus are able to help me someway to find an alternative resistance and confirm that it may be the right capacitor the one i put it in.
The main problem may be the wattage of that resistance.
it is soo big compared to the 2w....
the day after i bought the SM
i pay the money down, and then i got the schematics.
Now i changed the huge (in dimensions) 56ohm 1 watt that was fried, and replaced with a normal size same specs one.
when i plug the power back and switched on (witout no input neither speaker connected) it immediatly fried out again.
What now?
here is the schamatic:
scs175_preliminary_sm.pdf - File Shared from Box.net - Free Online File Storage
the restitor i am talking about is R44, the capacitor i have replaced (now i know it is correct value the one i put into)
is C20.
i really suspect, that since this component are really near the transistor Q11 whch is a C3421 it may be damaged itself and causing the resistance to burn out.
TR datasheet is here
Now a buzz sound come out from the speker at every volume ,and without no input connected.
please help me.
What now?
is C20.
please help me.
