I am thinking of designing a simple more practical solution to replacing the over priced, hard to obtain, failure prone A/C computer in an older Jaguar XJ-S.
The blower fan speed selector would simply need to be a pot with resistors possibly to control lo - med - high speeds on the fans.
The other task would be a circuit or simple solution for controlling the 'blend flap motors' These two stepper motors turn half moon shape flaps or doors inside the A/C unit box that control air flow to the different ducts for the vents on floor, center / side vents and defrost vent.
These servo motors are controlled by the existing computer design. The computer controls the current flowing to these and stops sending the supply when the flap door reaches it's end travel and can no longer turn when placing it in it's needed position to direct the air. Anything short of this would mean the motor continuing to turn and the gears inside the servo casing the motor is in being stripped. So the design I need to control these motors basically has to send the supply current only when needed and to stop the supply current flow when the flap is in it's final position and needs to stop along with the motor.
I have a link to show the cutaway diagram of what the blend flaps look like inside the A/C unit if anyone is interested in this project.
