issues with new picaxe 08m2 - wont do what the old 08m did - can any ony help?
madbutler
I need help with new 08m2 as a program that use to work on the 08m does not work with the 08m2 - any help would be appreciated you use to be able to knock the piezo sounder and it would remember the knocks and play them back by tapping with a motor. Now it does not record to the chip. (its from an instructable by AndyGadget (he is also tring to work the problem out) I use it with my students. The code follows:
#picaxe 08m2
'setfreq m4 'Not necessary at 4MHz - Saves 4 bytes
' Assign names to pins, variables to registers, and constants.
symbol rnd = w6 'Word variable : Current random number
symbol kdel = w5 'Word variable : Delay between last and current knock input
symbol cnt1 = b0
symbol kcnt = b1 'Number of knocks
symbol pptr = b2 'Pointer to knock delay storage array
symbol tmp1 = b6 'Reusable variable
symbol tmp2 = b7 'Reusable variable
symbol mic = pin2 'Microphone input (can also be output)
symbol knock = 4 'Knock motor output
symbol led = 0 'Indicator LED for testing
symbol pstart = $50 'Start of storage area
symbol tmax = 800 'Time-out value for delay - About 1.5 seconds
symbol settle = 80 'Settling time for microphone
' This section is where the person knocks.
' The time between successive knocks is stored
' until there is a pause of 1.5 seconds or so.
do 'Start of main loop
kcnt = 0 'Initialise knock counter
input 2 'Define mic as input to detect knocks
do
for kdel = 1 to tmax 'KDel is counting loops to determine time between knocks
if mic = 1 then 'Detect HI on microphone input
inc kcnt 'Add 1 to number of knocks
high led 'Flash LED to help debugging
pause settle 'Wait for oscillations to stop
low led
kdel = kdel + settle 'Add settle time to loop counter for accuracy
pptr = kcnt * 2 + pstart 'KCnnt is a word variable so need to add 2 to pointer
poke pptr,word kdel 'Write the delay from last knock to storage area
kdel = 0 'Reset kdel ready for next knock
end if
next kdel
loop until kdel >= tmax 'If no knocks for over TMax loops then leave loop
'This section will operate depending on the number of knocks detected.
'If there are no knocks it will exit.
'Other things happen on 13 or 20 knocks, or it will echo the knocks for any other number.
'The maximum number of knocks is 23 to fill buffer. Incorrect count after that.
select case kcnt
case 0 'Do nothing if no knocks have occurred
case 20 'If 20 knocks play go into prank mode
gosub twoknock
wait 30 'Do nothing for 30 seconds
for tmp1 = 1 to 50 'Make 50 knocks with random spacing
random W6 'Generates next random word
tmp2 = rnd + 100 'Make delay value from random value
gosub doknock 'Make a knock
pause tmp2 'Pause for the random delay number of milliseconds
next tmp1 'Loop until 50 knocks done
case 13 'Piecax's favourite number
tune 0, 7,($50,$35,$79,$35,$70,$0B,$F7,$75,$34,$77,$34,$70 ,$09,$F5,$70,$35,$79,$35,$70,$0B,$F7,$75,$34,$70,$32,$74,$B5,$70,$72,$74,$75)
gosub twoknock 'TUNE command plays the series of bytes as notes
tune 0, 7,($72,$74,$76,$77)
gosub twoknock 'TWOKNOCK knocks twice with suitable delays between
tune 0, 7,($72,$74,$76,$77,$3C,$72,$74,$76,$77,$3C,$70,$72 ,$74,$75)
gosub twoknock
else 'Any other number of knocks will be echoed
for tmp1 = 1 to kcnt 'Loop for the number of knocks
pptr = tmp1 * 2 + pstart 'Step in twos through buffer
peek pptr,word kdel 'Read back delay value words from buffer
pause kdel 'Wait the delay time (in milli-seconds)
gosub DoKnock 'Perform a knock
next tmp1 'Loop for next knock
pause 200
endselect
loop
' This section contains the knocking routines
DoKnock:
high knock 'Turn on motor
pause 70 'Wait 70 milli-seconds
low knock 'Turn off motor
return
TwoKnock: 'More compact to do this as subroutine
pause 550 'Two knocks with timed delays between for tune
gosub doknock
pause 700
gosub doknock
pause 700
return
If the 08M2 is the new 12f1822 chip then the most obvious thing is that the default HSINTOSC is now 16MHZ on a bare PIC. So verify the OSC speed with a simple on off routine and set the OSC speed accordingly. Can't help after that.
Have you checked with the experts at the PICAXE Forum? **broken link removed**
Ken
How can I boost the signal?
Yes I have placed it on a couple of different forums with no success.
Does any one now how I could boost the piezo signal a little? As with a transistor I get a strong signal and it picks up too much even slightest tap but then I can not use the piezo to play a tune back because of the transistor
So, you're trying to use the same piezo element for both an input sensor and an output speaker? Please post your schematic.
Ken
Schematic Attached
Hi I have attached Andy Gadgets Schematic for this from his instructable
Darren
  • Piecax.pdf
TR1, the N-MOSFET, is connected backwards. The drain (D) should be connected to the motor, and the source (S) connected to gound.
Ken
yes correct
Yes you are correct and i forgot to mention that he has corrected this in his notes and I have soldered the mosfet on correctly and this circuit does work with a picaxe 08m but not the new model released 08m2 which is suppose to be backwards compatible. I have even tried changing label to match new pin labels but it still does nothing.
Darren
This is what you have to do to get a piezo to be recognised by a PIC chip: <snip: spam link>
