Is This Circuit 100% matches This Pcb Layout
viri
hello dear friends
i wanna know if my PCB layout designed correctly
this is the PCB layout {i rendered it with component view to make it easy to check}
and this is original circuit
thanks for helping
No. Far from it.
1. You have missed out the 2.2R resistor from the 220R & 470uF junction to ground.
2. Your speaker decoupler is 100uF on the board yet 1000uF on the schematic.
3. You have missed out the 1R resistor to ground.
4. You appear to have two inputs for input -ve. Which are you trying to use?
5. You are using a 14V supply. Are you sure the 470uF 10V cap is rated enough.
