Is it possible to have 2 separate ADC inputs AND an external Vref?
bigal_scorpio
Active Member
Hi to all,
I am trying to figure out how to build a circuit using a PIC16F628A or possibly a 16F887A to read two separate voltages accurately and display them on LCD, for accuracy using an external precision Voltage Reference.
I understand the LCD part but I am puzzled about the use of external Vref and two input channels. I do understand how to divide the voltages to levels the PIC is happy with.
I have never used an external Vref before nor have I measured two voltages at the same time.
I have tried to understand the datasheet for the PICs but they seem to assume I know something already and its obvious to me that I don't.
Can anyone explain the way (if it is possible at all) to do this? Or point me to a link that explains it better?
Thanks, Al
I don't the PIC16F628A has a ADC. So how are you going to measure voltages?
The 16F887A has a ADC. You can use Vref- at ground and Vref+ at 2.5 volts from a good source.
You can not really measure two voltages at the same time. You will need to measure the voltages one at a time as close together as possible. (in time)
Pics like the 16f88x series permit an external precision reference Voltage for accurate ADC conversion.
However, there is only one ADC converter. U can switch the input to the converter by assigning different PORT pins to it during the program execution. When u do that u can effectively sample different voltage sources at each of those pins. There is a short settling time and a suggested max impedance of 10k per input. The settling time is on the order of a few uSeconds. Thus u can sample thousands of times per second. When u work at 10bit ADC accuracy for precision, it is useful to do sample averaging to eliminate 'noise' for a better result. If u have rapidly changing sampling voltages, this may not be possible.
The original post was asking a question. If Big Al has a 16f877 to hand, then Nigel's tutorial 11 is just what is required. I have made the 'analogue board' mentioned, programmed the chip and it all works very well.
It's hardly important if the chip is old, dead, non-existant, dresses as a woman. . . etc..
