Ir temp thermopile advice
You could use an op amp powered from a dual supply to cope with the +- o/p, then you can remove the offset once amplified by using a differential amp to get the range you want.
0 to 5v should be possible over the range you want, but you'd have to mess with offset and gain trimmers, and noise might be an issue too.
