IR receiver and transmitter
cyclops_returns
I need some help regarding a project. I need to build a project that receives an IR transmission and then just broadcasts it again. You think it's possible. If yes, can you please give me a schematic to that circuit? Any help would be appreciated.
Thanks for that prompt reply. The transmission will be from a tv remote to the TV (or something similar). Basically it will just get the input from a remote and should send it to the paired object. If it's possible, please suggest me a possible schematic
These are readily available for purchase. Do you really need to build it? You're reinventing the wheel.
Schematic
This circuit comes from a website with bad reputation (non working circuits), but I hope some expert here could help you fixing it
here is one i tested Universal RC5/RC6 IR transmitter/receiver for RC5 & RC6 codes
works off 16F628A
the Tx works as pre-define a code than press to send
see link below
PIC Basic projects
IR Receiver / Transmitter
You mentioned in that blog that such transmitter/receivers are readily available. I couldn't find one yet. any clues?
p.s.: I'm looking for the possiblity to transfer the IR signal from A/V remote controls to the components installed in a closed rack. should be as simple and as cheap as possible. 1:1 transfer of the picked-up signal
hello..
i'm new to electronic circuits.
i got a project to work on needing a circuit with the ability to record an IR commande from a remote control and re-transmis it when requested to do so..
is it possible to do so or it's easier to modify an enxisting remote control ..
thanks..
