Inverter DC to AC...
Power (P=ExI) is the constant here. Assuming you live in a different universe than Nigel, and inverters there are 100% efficient then:
12v X 75A = 900W in > Inverter > out 900W / 240V = 3.75A
or
240v X 75A = 18000W out < Inverter < in 18000W / 12V = 1500A
Either way...even in a perfect universe... that would be one big inverter :eek:.
Ken
yiefang said:
can we invert 12VDC, 75 Amp to 240 VAC, 75 Amp...is it possible to do?
same as the other 2 replys Can't be done
but if you want that amound of power we need to know more about your set up
if you have a battery bank than i would advise you to put some baterys in series so you have a higher voltage and than make an DC/AC converter
this is done mostly in the bigger sollar panel arangements
but from a single 12V 75 Amp source to 240V see reply from KMoffet
(but 100% efficiencie does not exist):eek:
Robert-Jan
Hi all,I'm new to using this means of communication so please forgive me if I mess up a bit:) My eye caught the thread on inverters while I was browsing.As my knowledge of electronics is very limited ,I would really appreciate help with a project to build an inverter or perhaps a few of them to help friends as well.We are subjected to load shedding in our part of the world 3 times a day for at least 2 hours each time and this will probably continue for at least the rest of 2008.I live in a small coastal town in South Africa and on making enquiries was told that there are waiting lists to buy inverters and generators.Components seem to be easily available.I am thinking :600 to 1000 watt ,deep cycle 100ah battery and batt.,charger.Usage would be for TV or PC and some lights.Any help would be greatly appreciated.
How much current are you passing through them? Are they heatsinked? Are you over driving them with too much voltage?
Haas said:
why do my power mosfets keep burning?
Many Reasons are Possible.
One is Inductive Kickback Voltage from the primary, causing the mosfets to break down.
Or Too Much Current.
Or No proper Heatsinks.
Or Many More things.
