birdman0_o
Active Member
Hey guys I can't get my code working perhaps one of you guys can find the fault
The interrupt's purpose will change however for now it just shines an led. There is a tri colour led attached, PWM is enabled.
Thanks,
Mike
; Reciever!
LIST p=16F628a
#INCLUDE <p16F628a.inc>
__CONFIG _CP_OFF & _WDT_OFF & _PWRTE_ON & _BODEN_OFF &_INTRC_OSC_NOCLKOUT & _MCLRE_ON & _LVP_OFF
ERRORLEVEL -302
CBLOCK 0x20 ; Delay files d1, d2 and d3 are at 20h, 21h and 22h
d1
d2
d3
count1
count2
count3
ENDC
ORG 0x0000
GOTO Init
ORG 0x004
GOTO Int
Init
MOVLW H'07' ; Turn off comparators
MOVWF CMCON ; ^
CLRF PORTA ; All pins low
CLRF PORTB ; All pins low
BSF STATUS,RP0 ; Select bank 1
MOVLW B'00011000' ; Pin ,4,5 input
MOVWF TRISA ; Move to tris a
MOVLW B'00000001'
MOVWF TRISB ; Port b is output except pin rb0 (interupt)
BCF STATUS,RP0 ; Select bank 0
;**** ENABLE EXTERNAL INTERRUPT ON RB0
CLRF INTCON
BSF OPTION_REG,NOT_RBPU
BSF OPTION_REG,INTEDG
BSF INTCON,PEIE
BSF INTCON,INTE ; Set rbo as int
BSF INTCON,GIE ; Turn on interrupts gei
CALL Set_timer
GOTO Main
Int
BCF INTCON,INTF
MOVLW B'00000000'
MOVWF PORTB
CALL Delay1
RETFIE
; Blue = b'00100100'
; Red = b'00000110'
; Green= b'00100010'
Main
MOVLW B'00100010'
MOVWF PORTB
CALL Fade
MOVLW B'00100100'
MOVWF PORTB
CALL Fade
MOVLW B'00000110'
MOVWF PORTB
CALL Fade
GOTO Main
Fade
CALL Pause
MOVLW 0x02
MOVWF CCPR1L
CALL Pause
MOVLW 0x10
MOVWF CCPR1L
CALL Pause
MOVLW 0x40
MOVWF CCPR1L
CALL Pause
MOVLW 0x80
MOVWF CCPR1L
CALL Pause
MOVLW 0xFF
MOVWF CCPR1L
CALL Pause
MOVLW 0x80
MOVWF CCPR1L
CALL Pause
MOVLW 0x40
MOVWF CCPR1L
CALL Pause
MOVLW 0x10
MOVWF CCPR1L
RETURN
Pause
MOVLW 0x02
MOVWF count3
D6
MOVLW 0x3F
MOVWF count1
D4
MOVLW 0xFA
MOVWF count2
D5
DECFSZ count2,F
GOTO D5
DECFSZ count1,F
GOTO D4
DECFSZ count3,F
GOTO D6
RETLW 0x00
Delay1
MOVLW 0x0B0
MOVWF d1
MOVLW 17h
MOVWF d2
MOVLW 0x02
MOVWF d3
Delay2
DECFSZ d1,F
GOTO $+2
DECFSZ d2,F
GOTO $+2
DECFSZ d3,F
GOTO Delay2
GOTO $+1
GOTO $+1
GOTO $+1
RETLW D'00' ; 499994 cycles
Set_timer ; Pwm period = (pr2+1)*4*tosc [1*10^-6] * tmr2 prescale value [16]
CLRF T2CON ; Pwm high = (ccpr1l+ccp1x+ccp1y(10bits)) * tosc [1*10^-6] * tmr2 prescaler value
CLRF TMR2
CLRF INTCON
BSF STATUS,RP0
CLRF PIE1
BCF STATUS,RP0
CLRF PIR1
BSF STATUS,RP0
MOVLW 0xFF
MOVWF PR2 ; Compare with 255
BCF STATUS,RP0
MOVLW 0x02
MOVWF CCPR1L
MOVLW 0x03
MOVWF T2CON ; Prescaler 1:16 and postscaler 1:1
MOVLW 0x3C
MOVWF CCP1CON
BSF T2CON,TMR2ON
RETURN
Thanks,
Mike
