Interrupt for a PIC16F877A
triplestak
Hey guys,
I have this program in assembly language that I did through MPLABIDE, but my goal is to get the RB0 to be the control Interrupt that makes the count (to 10) output to the LED (PORTA). I have it backwards. The count, automatically starts on the LEDS and when I press RB0 the count is interrupted or "paused" if you will. It continues when I let go. Does anyone have any suggestions to help me reverse this so that RB0 makes the count increment, and when I release it, the count pauses?
processor      16f877a
include <p16f877a.inc>
__config       _RC_OSC & _PWRTE_ON & _WDT_OFF & _CP_OFF &_LVP_OFF
;Set User ID Memory
;__idlocs        0x1234
org 0x00                     ;Adress for power up and reset
;*******************SETUP CONSTANTS*******************
INTCON  	EQU	0x0B      ;Interrupt Control Register
ADCON1	EQU	0X9F
PORTB	EQU	0x06
PORTA   	EQU 	0x05
TRISA 	EQU 	0x85
TRISB   	EQU 	0x86
STATUS 	EQU 	0X03      ;Status register address
COUNT   	EQU 	0x7F      ;This will be our counter variable
TEMP    	EQU 	0x20      ;Temp file for w register
		ORG		0x00
		goto          main 		  ;Jump over the interrupt address
;***************Interrupt Routine***************
 loop:			        ORG     	0x04            ;interrupt address
				movwf 	TEMP            ;temp storage for w
 				incf		COUNT,1       	;Increment COUNT
 				movlw 	0x0A          ;Move the value 10 into w
 				subwf   	COUNT,0       	;Subtract w from COUNT and result goes to w
 				btfss   	STATUS,0       	;Check the Carry flag. Set if COUNT is equal or greater than W
 				goto    	continue            ;If COUNT is <10, then continue
 				goto    	clear          	;If COUNT is >9, then clear it
continue: 		bcf 	 	INTCON,1		;We need to clear this flag to enable interrupts
          		movfw  	TEMP          	;Restore w to the value before the interrupt
         		retfie                		;Exit the interrupt routine
clear: 		clrf		COUNT       	;Set COUNT back to 0
      			retfie  					;Exit interrupt routine
;*******************MAIN PROGRAM*********************
 ;****The Interrupt Registers****
				bsf     	INTCON,7    	;GIE – Global interrupt enable (1=enable)
 				bcf		INTCON,1      	;INTF - Clear Flag Bit Just In Case
				bsf    	INTCON,4      	;INTE - RB0 Interrupt Enable (1=enable)
 ;**********Ports*****************
main:  			bcf		STATUS,RP0
				bcf		STATUS,RP1		;SET BANK0
				clrf		PORTA
				clrf		PORTB
				bsf  		STATUS,RP0    	;Switch to Bank 1
				movlw 	b'00000001'
 				movwf 	TRISB       	        ;Set RB0 as input
				movlw	006h
				movwf	ADCON1
 				movlw 	b'000000'
				movwf 	TRISA       	        ;Set PortA as output
 				bcf   		STATUS,RP0
				bcf		STATUS,RP1  	; Bank 0
				movf     	COUNT,0     	;Move the contents of Count into W
       			        movwf   	PORTA        	;Now move it to Port A
start:			        btfsc		PORTB,0
				goto		main
				btfss		PORTB,1
				goto     	loop           	;Keep on doing this until an interrupt
       	end                      			;End Of Program
hi Raj
Look at this edited version of your program, it works OK in simulation.
My advice would be to use the mnemonics names of the SFR [special function registers] rather than bit numbers.
Are you using MPLAB IDE.?
    processor 16f877a
    errorlevel  -302  , -207
;Set User ID Memory
;__idlocs        0x1234
;INTCON    equ    0x0B        ;Interrupt Control Register
;ADCON1    equ    0X9F
;PORTB    equ    0x06
;PORTA    equ    0x05
;TRISA    equ    0x85
;TRISB    equ    0x86
;STATUS    equ    0X03        ;Status register address
COUNT    equ    0x7F        ;This will be our counter variable
TEMP    equ    0x20        ;Temp file for w register
    org    0x00
isr:    org 0x04        ;interrupt address
    incf    COUNT,F        ;Increment COUNT
continue: bcf    INTCON,INTF    ;We need to clear this flag to enable interrupts
main:
    bsf    INTCON,GIE    ;GIE – Global interrupt enable (1=enable)
    bcf    INTCON,INTF    ;INTF - Clear Flag Bit Just In Case
    bsf    INTCON,INTE    ;INTE - RB0 Interrupt Enable (1=enable)
    bsf     INTCON,PEIE
    bcf    STATUS,RP0
    clrf    PORTA
    clrf    PORTB
    movlw    b'00000001'
    movlw    006h
    movwf    ADCON1
    movlw    b'000000'
    bcf    STATUS,RP0
idle_loop:
    nop
    goto    idle_loop        ;Keep on doing this until an interrupt
    end            ;End Of Program
1) Count isnt initialized before being put in PORTA at the beginning of code
2) No delay ,this will all happen very fast!
3) If you hold down a button using an interrupt on change, it will increase count once!
4) There is no need for an interrupt either ( I usually don't suggest using them for beginners)
5) If you go to CLear, you don't restore context of W (Doesn't matter for this code, but if you made it longer it would matter)
Reactions: 3v0
Hey Eric,
Thanks for the help. I really appreciate it. I got the program working now perfectly. Thanks for the tip on using the mnemonics rather than the bit numbers. For someone like me, it helps a lot. That way I don't have to keep on looking up the different bit numbers!!!! Thanks once again.
Raj H.
Hey Birdman,
You helped out again. I really appreciate the tips and pointers. I will probably be getting deeper into Assembly Language my next class, so this stuff really helps. By the way, on that post I made last week, I never did get that program working properly, but appreciate the help you gave me. My professor actually said it was a good program, so that was thanks to your help. Thank you.
Raj H.
