thank you very much chris.
I compiled, and to test for real, I'd give you the result after
I board have found that often, simulation and Flowcode
actual operation of the microcontroller through, there were problems
I test and I will post the result, thank you again
what software is simulating that?? the software i wrote resets the flags and turns off both leds, then shows the reset led for 5 seconds then you can press switch 1 again
I also tested on test plates (Breadboard)
identical results.
RB0 reset does well , but it should not prohibit the then switching interuptor (after off red led.)
