Interface SPDT relay 20 Amps with PIC32
jaj540
we hav to interface a spdt relay(20 amps) with pic32.. is there any available interfacing diagram for the same... pls help us... urgent :(
You could use a transistor circuit to drive it. Does the relay coil itself draw 20 amps?
I believe that a common approach is to drive the coil with a transistor or Darlington array. e.g. ULN2803. You also want a reverse biased diode across the coil to absorb the inductive emf when the transistor switches off.
