Interesting Meltdown
Ah, an induction heater. The thing it seems to fail to mention (though admittedly I only skimmed through it) is that it requires HIGH FREQUENCY alternating current. You can't just plug it into the wall socket (for several reasons). Definitely a fun project though. I remember seeing an induction heater set up in much the same way that was able to turn ice cubes red-hot before they melted. Think the video's on youtube somewhere.
Thanks for sharing!
Matt
EDIT: Just read the last part more thoroughly--they are using an inverter to supply AC current at 204 kHz. They DID mention the high frequency, I just didn't read it carefully enough :rolleyes:
Why not me?
Why I cannot see the video, not even the frame where it should show up? Just a blank white part after "Enjoy".
Java, ???Flash, Firefox or what?
Yup, Adobe Flash.
Adobe Flash uninstalled and reinstalled. OK now.
Why the coil has that extra reverse half loop?
I think it's just there so that both ends are on the same side of the coil, to go to the driver. It has no real purpose otherwise.
Off to a nap but a question first...
What could be a reasonable amplifier stage to drive such a coil at that frequency?
How to guess on the current (power) applied? I ignore everything (and more :confused:) on that subject.
By "amplifier stage" do you mean "transformer stage"? I have often heard of people using inverters or even automotive ignition coils to drive the coil. I think the webpage said an inverter was used for this particular one.
Wouldn't know where to begin guessing about the power usage.
Matt
