Ayne
The idea is, "Self generating electricity"
Explanation of the Picture,
1. We will give electric supply to the Motor from an electric source called V1(just for example), Motor will start rotating, it's shaft connected to Generator.
2. Generator also rotate, and will generate electricity. We will use this electricity(For home use).
3. As the motor will reached it's full speed Cross over switch will put the load of Motor onto Generator, and will cut off the supply of V1(electric Source) from Motor.
4. Now we look, Generator is running and generating electric supply, Motor is also running from Generator, and motor rotating the Generator's shaft.
(It is something close loop)
Now i want to ask it is POSSIABLE??? or it just a bad idea.
If this system will not work then why??
Thanks.
Thanks.
