solidstate
Project Idea
I have an idea for my final year project (in electronic and electrical engineering) but I am wondering if its too easy/hard.
I have a time limit of about 3 months to complete the project, keep a logbook, write a report, do posters etc etc....
My idea is as follows:
A handheld device which can be taken on hikes, walks, or pretty much anywhere. It would log the time, humidity, pressure, temperature and location (gps) onto an SD card. It can be logged onto the card in kml format and then be opened through google earth.
The path taken would be shown on google earth. I would then like to find out whether there is a way to include the sensor data for each data point.
I was also thinking of including a lcd display on the device so that it would be useful in the field and not only once the user has downloaded the info to a pc.
I would be using an atmega162 as the brains of the project. I think it should be able to handle all the necessary code (sd card interface and logging as well as the sensor calibration and talking to them).
A GPS receiver would be used. I would just need to parse the GPS stream as I would only require the time and co-ordinate info.
The interfacing of the sensors I have seen all seem to work off I2C which I feel I could be able to work out easily enough.
I am no expert in coding but I do have some experience and therefore think I would be able to take this on.
One of the main things I am worried about with this sort of project is the fact that I'm not sure if there is enough theory involved with the proejct. As lecturers will be marking this, they love the theory behind everything and therefore I'm not sure about this.
I suppose I would define the interfacing between sensors and uP as well as the interface with the SD card and GPS.
I suppose the main reason for posting this topic is to find out what anyone thinks of such a project, whether they think it is of high enough standard for a final year project in a masters degree. Do they think the idea is good/silly. etc.... any constructive critisicm is welcomed.
Maybe you can think of something extra to add or maybe think its too much to pull off in 3 months (all solo).
Thanks for replying,
ps: sorry for the quick and slightly unorganised post, I am about to go to a lecture.
