The MPLAB ICD 3 in-circuit debugger system is similar in function to the MPLAB ICD
2 in-circuit debugger system, but surpasses it in speed and functionality. The MPLAB
ICD 3 also:
• Features USB high speed
• Is USB powered
• Is a hardware accelerator
• Provides a programmable voltage power supply
• Eliminates the RS-232 port
• Includes a diagnostic self-test interface board
The standard ICSP RJ-11 cable does not allow for clock speeds greater than
about 15 Mb/sec. dsPIC33F DSCs running at full speed are greater than the 15
Mb/sec limit.
The link does not provide enough info, it could be add for the PICkit2.Coming soon ... **broken link removed**
Pickit3 - which sorta puts the EPE cheapie into perspective.
That $70 gets you a target board too, so you can probably buy the programmer without it for a bit less. Looks like the major addition will be (future) support for the 32-bit chips.Found this with more info. Mostly a press release but it talks about target chips. Price is $70.
