IC current drive interface: BJT or MOSFET?
solis365
Hi, I have made a few posts on here about a project I'm working on where I am PWMing some high-power LEDs. (The thread is here). Since the LEDs are high power (350-700mA), I needed some sort of way to drive them from a microcontroller PWM output pin. As seen in the simple schematic I supplied on that thread, I had planned on using MOSFETs.
However, now I am beginning to think that BJT's may be easier to implement. Here is the plan:
NPNs will take the place of the FETs in the schematic; however the emitters will go directly to ground. Given that base-emitter voltage (Vbe) varies very little, you can approximate it to be constant (lets say 0.7V). Thus, your base voltage Vb will be 0.7V if the emitter goes to ground. If the IC pin's logical high is 5V, then you will need to place a series resistor (Rb) between it and the base of the NPN that will drop 4.7V. This resistor will limit the base current (Ib) by ohms law:
Ib = (5V - Vb) / Rb
Since the Emitter current (Ie) of a BJT is β*Ib (or hfe * Ib) and collector current (the current drawn through the LEDs) is
Ie - Ib = Ic
So by using Rb to set Ib, Ie = β*Ib , --> Ic = (β - 1)*Ib
By selecting NPNs with a decent β, and then selecting the resistors, I can just control the amount of current I pull through the LEDs.
I have access to large amounts of NPNs so I can just go through and test them and select ones with similar β-values.
Seems easier to work with than FETs, or is it just me?
The fact that Vbe remains almost constant makes it a lot easier to work with.
Any opinions?
And thanks for all the help
The beta of a transistor applies only when it has plenty of collector to emitter voltage. All transistors have a "max saturation voltage" spec when the base current is 1/10th the collector current.
You cannot use the beta to control the conduction of transistors because the beta increases as the transistor heats.
The max allowed output from a microcontroller pin is 25mA. Then a transistor will saturate properly when the collector current is a max of only 250mA.
You can test many transistors to find a few that saturate well with a higher collector current, or use darlington transistors or Mosfets.
You need a current-limiting resistor in series with the LEDs.
