I2C slave pic transmit problems
hhhsssmmm
Hello
I have tried to solve the problem my self but i fail. I can not get the slave pic to transmit a single byte to master
pic via I2C interface. I have however successfully completed I2C link when master send byte to slave...then it
works fine and i can get result on my LCD screen too. But can not get things to work the other way around from
SALVE to MASTER.
Right now im just getting garbage on my LCD screen when i run the two programs as below.
I use the following...
PIC i use is PIC18F4423 (MASTER) and PIC18F2420 (SLAVE)
Master @ 20Mhz ceramic clock
Slave @ 8MHz internal clock
compiler used C18
Please can someone look at my code below and help me please to solve this problem
Thank you
Haseeb
MASTER CODE
//In main() function...
    OpenI2C(); //INITIALLIZE & Configure I2C PORT
    StartI2C(); //Generates a Start I2C condition
    IdleI2C(); //Loops until I2C BUS is Idle
    if(DataRdyI2C() == 0) //proceed if buffer is empty
        //Sends Slave address
        if(WriteI2C(0x69) == 0) //ACK not received from Slave
            I2C_Error(); //Stop and rest I2C if link between PICs fail
    BCD = ReadI2C(); //save the data read
    NotAckI2C(); //Generates a Not Ack condition after reading data
    StopI2C(); //Generates a Stop I2C condition
    SendLCD(0x80,0); //activate LCD line 1
    //print the data byte on LCD
    SendLCD(BCD,1);
    while(1); //loop forever
//My customized I2C functions...
    void OpenI2C(void)
        //Reseting MSSP registers
        SSPCON1 = 0x00; // power on state
          SSPCON2 = 0x00; // power on state
        //Selecting & Configuring I2C Master mode
        SSPCON1bits.SSPM3 = 1;
        SSPCON1bits.SSPM2 = 0;
        SSPCON1bits.SSPM1 = 0;
        SSPCON1bits.SSPM0 = 0;
        SSPSTATbits.SMP = 1; //Slew rate set to NORMAL speed @ 100kHz
        SSPADD = 0x63; //setting baud rate 100kHz (NORMAL)...PIC running @ 20MHz
        SSPSTATbits.CKE = 0; //Disable SMBus
        PIR1bits.SSPIF = 0; //reset MSSP interrupt flag bit
        SSPCON1bits.SSPEN = 1; //Enable I2C Master port
    }//end of OpenI2C()
    void NotAckI2C(void)
        SSPCON2bits.ACKDT = 1; // set acknowledge bit for NOT ACK
        SSPCON2bits.ACKEN = 1; // initiate bus acknowledge sequence
    }//end of NotAckI2C()
    void IdleI2C(void)
        //Test and wait until I2C module is idle
        while ( (SSPCON2 & 0x1F) | (SSPSTATbits.R_W) )
            continue; //keep looping until idle
    }//end of IdleI2C()
    unsigned char DataRdyI2C(void)
        if(SSPSTATbits.BF == 1)  // test if buffer full bit is set
            return 1;          // data in SSPBUF register
        else
            return 0;          // no data in SSPBUF register
    }//end of DataRdyI2C()
    unsigned char ReadI2C(void)
        SSPCON2bits.RCEN = 1;     // enable master for 1 byte reception
        while (SSPSTATbits.BF == 0); // wait until byte received
        while(PIR1bits.SSPIF == 0); //wait for interrupt
        return SSPBUF;    // return with read byte
    }//end of ReadI2C()
    unsigned char WriteI2C(unsigned char data_out)
        SSPCON2bits.ACKSTAT = 1; //reset ACK bit flag
        SSPBUF = data_out;       // write single byte to SSPBUF
        if(SSPCON1bits.WCOL == 1)  // test if write collision occurred
            SSPCON1bits.WCOL = 0;     //Reset collision bit
            while(SSPSTATbits.BF == 1);   // wait until write cycle is complete
        if(SSPCON2bits.ACKSTAT == 0) //Was there an ACK sent from DS1307?
            return 1; //DS1307 sent ACK
        else
            return 0; //No ACK was sent
    }//end of WriteI2C()
    void StartI2C(void)
        SSPCON2bits.SEN = 1; //Initiate Start condition
    }//end of StartI2C()
    void StopI2C(void)
        SSPCON2bits.PEN = 1; //Generate Stop condition
    }//end of StopI2C()
    void I2C_Error(void)
    }//end of I2C_Error()
SLAVE CODE
        //I2C SLAVE mode, 7 bit address, with Start & Stop bits interrupts enabled
        SSPCON1bits.SSPM2 = 1;
        SSPCON1bits.SSPM1 = 1;
        SSPADD = 0x69; //SLAVE address is (7bit). LSB bit is set to 1 for read
        SSPCON1bits.CKP = 1; //Clock Released
        d0 = SSPBUF; //clears BF
           SSPCON1bits.SSPOV = 0; //Clear Buffer Overflow
        INTCONbits.INT0IF = 0;  //Reset the INT0 External Interrupt Flag bit
        INTCON = 0b10010000;  //Enables all high priority interrupts
                                //Disables all low priority peripheral interrupts
                              //Disable the TMR0 overflow interrupt
                              //Enables the INT0 external interrupt
                              //Disables the RB port change interrupt
    d0 = 'S';  //assigning the transmit byte
    while(1);
//In ISR function....
void HighInterrupt (void)
    if(PIR1bits.SSPIF == 1) //if MSSP interrupt
        if(SSPSTATbits.R_W == 1) // Slave address varified
           SSPBUF = d0;          //TX data byte
           SSPCON1bits.CKP = 1;     //Release clock
           d1 = SSPBUF;             //empty buffer
Hello!
You can read the Application Note-AN554(software simulation I2C bus) on the Microchip Website,or find others on the Website.
The Link as follows
Regards
klchang
