I want to help :(
Akram450
want to know the maintenance of the Alauselescob
I also want the circuit diagram
The problem that I faced:
Vertical and horizontal line does not appear on the screen .
These are picture I have a device
Thank you for helping me
Can you post a photo showing the front of your scope so we can see the positions of all of the knobs and buttons?
A
This is the manual for the series of scope you have. What cowana is asking is how you have the scope setup? For example triggering? To see a display the scope needs to be correctly setup.
See page 39 of the linked to procedure for initial settings to see a trace.
Ron
Turn on POWER
Turn all of the red knobs to CAL.
Coupling Auto
Source ch2
Hold OFF = CCW
Time base MAIN
CHA 1 GND
CHA 2 GND
Vert Mode CHA2
MAIN TB - Somewhere in the mS range
If the trace is NOT Visible (Press and Hold Beam finder)
Adjust, horiz position, vertical position, and intensity so something is visible and trace is somewhat ceentered
Release the beam finder
Adjust intensity
Adjust, horiz and vertical position.
Adjust focus.
You should have a horiz line on channel 2.
