Dan Rodgers
I have a friend who is a chiropractor out in the country-the table he works with has a 110 volts AC to 24volts DC converter that pulls 7.7 amps of current.Now heres the thing-when there is a power outage during a storm,he either needs to raise or lower the table somehow,and he's thinking of running an automotive "cigarette lighter" 12volt DC to 110 AC volt converter(from his vehicle outside) rated 85 watts continuous power with a 15 amp fuse.Do you think he would burn up something here? He only needs to put the table back into the "down" position usually.It uses a motor to raise or lower the table,this is the 24 volt operated part.Anyone?would you think he would need a heftier DC to AC converter?Thank you!........dr
