I am looking for a servo motor controller that has programmable memory. What I need this board to do is this.
Using a simple on/off switch
Example:
Switch is turned to "on"
first servo motor turns continuous for a pre-programmed distance
then stops.
The second motor once the first has stopped starts and turns a specific distance then stops.
When the switch is turned to "off"
The motors reverse there respected courses
(2nd motor starts moves back to start point then stops)
(1st motor then starts, moves back to it's original position, then stops)
The board must remember these motions everytime it is switched on and off. Also I must have speed control. I will be using typical r/c motors.
If anybody can tell me what I need it would be appreciated
Thank you :?
Example:
then stops.
Thank you :?
