i need datasheet help me plzzzz
hakhan
hello every one plz help me i m confused about datasheet . plz any one explain what is datasheet and plz give me datasheet about the following ICs {AND,OR.NOT,XOR,NAND,NOR}
plz give me quick responc i will be thank full
mvs sarma
Hi, suppose you want to use an IC, for example, 74LS125 and you have the IC with you , but you don't what this is and no other info known. Such cases to assist users what is the chip, pin details, working voltage limits ete can be read from the so called data sheet
the data sheets are as per manufacturer part number. say 7400 for a pack of 4 NAND gates in TTL technology.it is available in various forms.
you may download freely data sheets for most of the ICs, Transistors and even small component like a signal diode, from ALLDATASHEET.COM - Data sheet search site, Data sheet search site for Electronic Components and Semiconductors and other semiconductors. and many other such sites. In this site you can search by function like NAND gate-- you will get answers
All the best
hakhan
very very thanks sharma jee
All the best
sharma jee very very thanks i got the idea of datasheet but still confused in searching my required gates datasheet plz kindly help me alitl more actualy i m not expert on internet
audioguru
Most Helpful Member
There are about 6 families of logic ICs:
1) Some are old and others are new.
2) Some are fast and others are slow.
3) Some use almost no power and others use a high amount of power.
The families are RTL, DTL, TTL, ECL, Cmos and High Speed Cmos.
You must learn about their properties so you can select the right family.
audioguru
Most Helpful Member
Why would anybody use antique 7400 series logic ICs today? Only for school-work?
kchriste
Forum Supporter
They still make and sell the 74ACT, 74HC, 74HCT, etc series of IC's which are functionally equivalent to the original plain 74 series. In some high speed applications, they are the way to go. Most slow-medium speed functions can be created cheaper and simpler using a microcontroller or gate array IC.
mvs sarma
Just check from local market of your city, what chips you get
whether 74LS seires, CD40xx series, 74HC series
then we can suggest you
there uis also a cross table listing available
suppose you can locally get CD400series ICs, please see this link for more data
http://www.kpsec.freeuk.com/components/cmos.htm
study carefully list out which are numbers you need
then again some one can see.
hakhan
thanks{khan}
4000 series CMOS Logic ICs
sharma je i got it thanks i lot i was needed 74LS series
mvs sarma
At places where students are blessed with guru's like you they are uplifted to newer standards.
but when a Local guru and Local college or school, and local market can support only specific types, and as you rightly pointed , understanding concepts of logic gates at school education, old /obsolete things are still used, perhaps. a clear example of using LM741, 555, Z80 (what a luggage of additional chips needed)and 8051are being used.
At lest the concept of opamp is practiced.
Fear after another decade people who are good in analog would be rare to find.
audioguru
Most Helpful Member
I studied RTL and DTL logic IC families in university.
I designed circuits with 74xx series ICs from 1975 to about 1978 (30 years ago!) when I started using 74LSxxx ICs. In 1980 I started using CD4xxx cmos then later 74HCxxx fast Cmos logic ICs.
