i have problem with small IC,s
imgemini
hi friends
i there any way i can make my ICs pic big to i can work easyly with them .......these days IC r coming micro..so working with them on semple PCB is diffecal
Exo
Active Member
what do you mean? SMD ic's?
for most IC's you can choose the package when you order them. if you order PDIP you get a normal ic...
If you want a part that's only available in SMD then the only option is to buy the biggest SMD version available and make a PCB for it...
If you don't have the ability to produce your own pcb's you can always use SMD protoboards. Testboards with SMD pads printed on them...
Oznog
Active Member
I assume you're talking about surface mount components. There is a product line called "SurfBoards" which mount vertically and make a single inline of normal protoboard pin spacing for you to use. They do cost a bit much and take up an awful lot of room, but it does allow you to get you prototyping done.
imgemini
hi
i m working with small size VCO . with 8 pib itvery small i find diffcult to sold it in normal PCB just try to ask a idea that make my life easyer :)
EE World Online Articles
Loading
