Hi all, finally found a page where people could help me, here is the issue.
Had the idea to build a damin the creek beside the house 1 month ago, the objective is to build hydropower setting for lighting the backyard with leds bulbs at night..
So i jumped into that DIY pelton wheel/ 3 phases axial fluxdynamo project.
The dam and artificial stream are done.
The pelton wheel and the dynamo casing are done.
The dynamo still won't produce volts and amps enough for charging a battery bank.
All i found in my area is 19 gauge wire and 3/4 x 1/8 neomagnets.
I
Started with big 150 feet coils (? Turns) and big ceramic magnets and tryed many differents settings whit no succes.
Thought my last setting with a 6 coils (120 turns, approx 2 inch large) stator between two 8 neomagnets rotors would finally produce some juice. It dont.
The rotors are close enough so the fixed back rotor gets the front loose rotor turning with him. All the 3 phases connection are OK. Waiting to get a amp "clue" before buying the rectifier and other electronic parts.
So here ate the settings again
8 inch diameter stator with six 19 ga coils with a 3/4 center hole wired in a 3 phases star.
16 3/4 large and 1/8 thick neo magnets setted on two rotors turning as closr as possible each side of the stator.
No succes, should i go with a thinner gauge or bigger magnets?
Been working on this project for a while now, and i'm absolutely not a tech.
Ima carpenter loving DIY projects. I read a lot about dynamos but cant find why it doesnt get ant sign of life on the multimeter.
Thank for your help
I
Thank for your help
