how to set time and date from keypad
hi dear
i am doing Rtc using ds1307 with pic16f877a
i need a help how to set time and date from keypad by using this function
ds1307_set_date_time(31,12,9,2,23,59,55);//day, month,year,dow,hr,min.sec
from this
void ds1307_set_date_time(BYTE day, BYTE mth, BYTE year, BYTE dow, BYTE hr, BYTE min, BYTE sec)
sec &= 0x7F;
hr &= 0x3F;
i2c_start();
i2c_write(0xD0); // I2C write address
i2c_write(0x00); // Start at REG 0 - Seconds
i2c_write(bin2bcd(sec)); // REG 0
i2c_write(bin2bcd(min)); // REG 1
i2c_write(bin2bcd(hr)); // REG 2
i2c_write(bin2bcd(dow)); // REG 3
i2c_write(bin2bcd(day)); // REG 4
i2c_write(bin2bcd(mth)); // REG 5
i2c_write(bin2bcd(year)); // REG 6
i2c_write(0x80); // REG 7 - Disable squarewave output pin
i2c_stop();
i have 4 four keys connected porta with pullup
i have to do menu function to set time and date
any one help me i am using ccs c complier pic 16f877a
only 4 keys?
how about making them:
Increment, Decrement , Next , Set
first two would edit parameter value,
next would be used to select parameter to be edited,
set would call function that finally writes the parameters to DS1307
thanks panic ,give me a sample code to slelect menu mode to set time (call function)
keys are menu ,up ,next,set.....
I use 4 keys on ALL my units....
Up, Down, Enter and next... If two keys are pressed at the same time ( up and down ) it clears.
I also have done a shift on the first key, so I can have six functions...
Here is my security entry function:- Maybe it will help.
char security()
	int code = 0;
	char key=0;
	I2cReadStr(lcdbuf,0x390,16);  // ignore this its an external string in I2C eeprom
	LCDline(1);
	LCDprint(lcdbuf);
	while(1)
		sprintf(lcdbuf,"      %04d      ",code);
		LCDline(2);
		LCDprint(lcdbuf);
		key = keyhit();
		if(key == 4)
			if(code == CODE ) return 1;
			else return 0;
		if(key == 1 && code < 10000 )
			code*=10;
		if(key == 2 )
			code++;
		if(key == 3 && code)
			code--;
		if(key == 5)
			code = 0;
