techyguy717
Actually I need to reset the BIOS of a laptop, so I just need to desolder one of the two leads for an hour. (So the bad BIOS config can clear)
I'm an expert computer technician, but an out of practice "Solder Certificate Holder".
I've removed the solder from the lead (using solder wick), but I can't get the lead up from the solder pad. The pad is big and the lead is as long as the pad. Because of the size of the lead I just cant seem to get it free from the pad.
I don't want to damage the board or nearby components with excess heat. What would you recommend? I don't have a hot air gun. I have a 25 Watt 750 degree Weller.
If I can't safely remove the lead, I'm about ready to clip off the battery, tin some copper wire, then solder it back on. Electrical taping the battery side onto the new wire leads.
