Hello,
I have a board which is driven by a half-wave rectifier SMPS, meaning its configuration is like this:
- The Input voltage is AC mains (110VAC/220VAC, 50Hz/60Hz).
- The mains voltage is rectified by a single diode (Anode's connected to the Live wire) and a single (electrolyte) capacitor that comes after the diode, and connects to the Diode's Cathode and Neutral wire.
- The rectified voltage (~311VDC in the case of 220VAC mains) goes into a buck converter which I assume that works in discontinuous mode since the current that is drawn from the converter is 350mA maximum, normally the drawn current is around 100mA.
I own a dual channel digital oscilloscope.
I'd like to measure the active (real) power that my board consumes from the main, using my scope.
I'd be happy to receive guidance on how to perform such measurement.
Thank you very much.
Any help is much appreciated.
