What's an omenio aerial?
What makes you think there is any magic that would allow this? Antennas are passive devices and their gain depends only on their geometry and their placement with respect to the environment. If you want to experiment I suggest you download a copy of EZ-NEC so you can try various combinations and plot the results.Thank you for your Information.
I would like to increase the Db to 24 how would I go about this .
Do I add extra sector's ? will this change the Ghz value.
With that many elements, tuning it should be relatively simple and straightforward. RIIIIIGHT!
Maybe the OP would like to borrow your VNA for a while. Mine is occupied.Exactly!
Search for details of "Discone" antennas.
Isn't a 'discone' a multi-band low gain aerial?.
Great only +24 dB to go to reach the OPs original requirement. At least we're not heading for an omnidirectional antenna with a gain less than 0 dBiYes, known for it's super wide bandwidth (>10:1 range with good SWR IIRC). It's shaped like a vertical cone with a top hat. Some small gain as all radiation is in the horizontal plane.
