How to increase the accuracy ?
Hi, I'm using a 10k POT to change the position of the servo in degrees , im using an ATmega8 , codes are in C , im using a 5V source for the pot , and 5V for AVCC .
I get for 50mV about a 100 count change in the adc , i wanna get a 0.5Degree resoultion , what to increase ?? increase the resoultion of the ADC ? or the POT value ?
Post your schematic. What needs to be changed is dependent on how your voltage divider is setup.
.5 degree out of 360 degree (assuming your pot is single turn) = 1/720. so you need a 10bit or higher adc to do it.
smanche, its a simple voltage divide , 5V---POT ----> GND
millwood, its a servo motor , it rotates from -90 to 90 ;
so only changing the ADC resoultion not the Pot's value ?
The pots value has nothing to do with it, as long as it's low enough in value to correct charge the sample and hold.
Does a servo even give 0.5 degree resolution?, how wide is the dead band on one?, and what is the backlash like?.
Your right nigel , but why a 50mV , puts a 100 increase count in the digital value ?
would you tell me the calculations of how the required accuracy affects the resolution of the ADC
It's dead simple - divide 1 by the resolution of the A2D and multiply by 100.
For 10 bits this gives roughly 0.1% resolution, and for only 8 bits it gives 0.4% resolution.
For 180 degrees travel, and 0.5 degree resolution you need 0.3% resolution, so 8 bit isn't good enough - but 10 bit should be fine.
Misunderstood the question. Thought he was saying he was only getting a 50mV rise from the POT. :(
